Full Screen Video Issue
  • 1 antwoord
  • 3 hierdie probleem
  • 10 views
  • Laaste antwoord deur Paul
Although New Build Claims -- Fixed the problem that caused full screen YouTube videos to exit and switch to portrait mode when changing quality or speed. But issue still persist screen doesn't rotate to Landscape mode in full screen mode. It stays in portrait mode with caption below entering in Full Screen. Works Flawlessly in Firefox Nightly
Although New Build Claims -- Fixed the problem that caused full screen YouTube videos to exit and switch to portrait mode when changing quality or speed. But issue still persist screen doesn't rotate to Landscape mode in full screen mode. It stays in portrait mode with caption below entering in Full Screen. '''Works Flawlessly in Firefox Nightly'''
Hi
This does appear to be an issue that our developers are aware of and are looking into. You can follow progress on this and add comments at:
https://bugzilla.mozilla.org/show_bug.cgi?id=1827583
